- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
VPN bypass not working in Orbi RBK22
- Mark as New
- Bookmark
- Subscribe
- Permalink
When I connect to my company VPN from home, I don;t get the DNS from work. My admins at work keep asking to set VPN bypass on my wifi router but there is no setting like that available. My previous router had no issues like this.
We use the Cisco umbrella client in our company setup and it forwards DNS queries to where needed.
The current workaround for me is to stop the unbrella client service and I am able to then get proper DNS response.
I have a ticket open with Netgear but so far did not get any resolution and they have not called back after August end.
Can anyone tell me how to setup VPN bypass on this router? I am contemplating returning this router if this is not fixable in few weeks.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: VPN bypass not working in Orbi RBK22
What FW is currently loaded?
Not sure if this is any help:
https://community.netgear.com/t5/Orbi/Orbi-VPN-no-network-access/m-p/1644658#M41983
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi @NLok
May I request for the following information:
- What is the exact error message when trying to connect?
- Was this working before using older firmware version?
- Can you also describe your network setup?
Blanca
Community Team
- Mark as New
- Bookmark
- Subscribe
- Permalink
Any progress on this?
- Mark as New
- Bookmark
- Subscribe
- Permalink
No error, when I try to ping my companies Hosts (after conencting to Cisco VPN) it sends request to internet instead of local DNS and hence I cannot connect to company resources. I have to turn off the umbrella client and then I get local DNS resolution.
It was never working since day one of this router purchase. It was working with my D-Link router with no special setup.
I have Spectrum internet which comes to their Modem setup in bridge mode, Orbi router connected to 1 port of the Modem.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Something to try, set the ISP modem back to router mode, then try using the Orbi in AP mode to see if the problem continues.
You can also try setting the Orbi as router while the ISP modem is in router mode and place the IP address the Orbi gets from the modem into the modems DMZ and see if the problem continues.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Will try that tomorrow
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Had to abandon my testing as my ISP said router mode will cost me $5 per month. Also, just for testing I could not connect to the router/modem so they told me to turn in my router/modem and get the new modem with just 1 port/WAN which is in router mode by default etc. So will try that later.
- Mark as New
- Bookmark
- Subscribe
- Permalink
The new modem which has 1 port should be running modem mode, not router mode. A stand alone Modem. Which modem modem would be preferred.
Let us know the Mfr and model of this new modem.
Does your ISP support users having there own modems? Buying your own modem?
- Mark as New
- Bookmark
- Subscribe
- Permalink
I had the same problem with the Orbi RK50 non-guest wifi network and my company's Cisco Umbrella client (which I can't deactivate). A workaround that I used was to use the Orbi's guest wifi network.
