Reply
Highlighted
Follower
Verizon Fios Router G3100 Compatibility with Orbi
I am setting up new Verizon Fios tv and internet service.
The router they provide is now the G3100 wifi 6 router. It says "This product is only compatible with the Fios Home Wi-Fi Extender (Model #E3200), and many features, including SON feature will not work as designed when paired with a different extender."
I already bought the Orbi RBK53S. As I look through all the posts here, it seems as though most people have the Quantum G1100 router and are able to connect without issue. Does anyone know if the Orbi can actually work with the Verizon G3100? If not, I may need to go with another provider.
Thanks you in advance.
Model: RBK53|Orbi AC3000 Tri-band WiFi System
Message 1 of 2
Highlighted
Guru
Re: Verizon Fios Router G3100 Compatibility with Orbi
Should be however your FIOS modem/ONT already has a built in router. This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
My Setup (Cable 900Mbps/50Mbps)>CAX80>RBK853 v3.1.16.6(Router Mode)
Additional NG HW: C7800/CM1100/CM1200/CM2000, Orbi CBK40, RBK50, R7800, R7960P,
EX7500/EX7700, XR450 and WNHDE111
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 2452 views
  • 0 kudos
  • 2 in conversation
Announcements
