Fourcats
Mar 11, 2020Aspirant
WPS process is in progress, please apply the changes later
This is actually an issue with the RBK22, but it wasn't a model that I could pick from in the list.
I recently bought the RBK22 and I'm trying to make some security changes on the orbilogin.com website. Any changes that I try to make are met with the following message: "WPS process is in progress, please apply the changes later". I cannot seem to change anything on the website. Any suggestions on how to correct this?
Try a factory reset on the RBR and RBS and walk thru the setup wizard with a wired PC. Leave the RBS off for now. Make the changes you need to on the RBR after the setup wizard completes. When you done, add the RBS to the RBR.
- FourcatsAspirant
Thanks! I will give that a try.
