ivankenzo's avatar
ivankenzo
Wifi Interference
When I connected to Orbi (AP name : Kenzo) and checked using Wifi Analyzer apps i see that the interference is 90%, is this normal?
I tried to change the channel but got the same result.
channel
90% interference
So I tried to connect to another router (AP name : Huawei F333) using different ISP; redo the analyzer and i got 0 interference.
0 % interference
Please advice
Thanks
  • The orbi router and satellites all use the same channels. So your wifi analyzer is seeing the other networks and thinking they're interference when its actually a design feature.
1 Reply
  • plemans's avatar
