Carbs314
Oct 21, 2022Follower
Wifi not connecting to main SSID
I had a power failure and when my orbi came back the only way i can use Wifi was access the guest network i had setup. Every device in my house wont connect to the main SSID. I have rebooted the main Orbi and all the satellites several times. I also rebooted my main connection from AT&T.
Any ideas ? I dont want to have to change hundreds of devices to a new SSID
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network. - CrimpOnGuru - Experienced User
Could you please provide more detail:
- Do WiFi devices list the primary SSID as an available WiFi network?
- What happens when a devices attempts to connect to the primary WiFi network?
Does it report an error? or.....
