erlwebmail's avatar
Aug 09, 2021
Yet again: setting a reserved address on an Orbi
The post at https://community.netgear.com/t5/Orbi/Orbi-setting-up-static-IP-address-for-one-of-my-quot-appliances/td-p/1883572 has been locked, so I can't add to it. Sorry. I also consulted https://community.netgear.com/t5/Orbi/Orbi-DHCP-address-reservation-is-ignored/m-p/1797338#M70052.
I followed the instructions in the first post above, went to "Advanced, Setup, LAN Setup," added reserved address 192.168.1.99, and clicked on "APPLY". It added  an entry. I exited the Orbi, rebooted the computer, but it kept the same old address. I rebooted the router and then the computer. ...no joy- -  it was still running on the old address, not the reserved one.
So, I changed the reserved address to 192.168.1.101 and APPLIED the reservation. I went to "Attached Devices" and lo-and-behold, the address was shown as 192.168.1.99 ! I quickly went back and edited the reserved address to 192.168.1.099, thinking it might need all 3 digits, and APPLIED. Going back to the "Attached Devices" list, it kept the 192.168.1.99 address.
I guess it's set up, now, but I don't know for sure.  ...think I'll reboot computer & router and see.
Any thoughts?
  • ...looks like my fumblings-around might have worked somehow (I was doing it when you replied; thanks for being so speedy), but just in case, I followed your ipconfig/release suggestion, rebooted all, and it came up with the correct reserved address.Thanks.
  • FURRYe38's avatar
    Is the one device using a static IP address or is it set for Auto obtain IP addressing?
    You might do a ipconfig /release on the PC after ensuring the IP address is set and applied on the RBR. Reboot the RBR once more then reboot the PC after doing the /release command.
