MitchellThomas's avatar
Aug 20, 2019
Youview BT/Plusnet TV Issues
Wonder if anyone can help. I have Plusnet TV with Youview, I am using the Openreach Huawei modem and RBK30 Orbi system with IGMP proxy enabled and BT IGMP support enabled also. After about 5 minutes of watching an IPTV channel on the Youview box, I am presented with the IPC6023 error. Has anyone managed to resolve this?
Only other option I have is to setup Orbi in AP mode and use the ISP supplied router for DHCP. Id rather have the Orbi handle DHCP etc., the ISP supplied router has locked down DNS :(
  • FURRYe38's avatar
    Modem Combo Units:
    This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
    Couple of options,
    3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
    You might try Option #2 first, if not, see if option #3 works better...
    • Looks like option 3 it is! I’ve read a number of people having the same issue, is this something Netgear can take a look in to?
      • FURRYe38's avatar
        This is probably something that may not be support officialy as some ISPs or TV services require the use of there devices.
        Might check and see if disabling IGMP protocol on the RBR doesn't anything. Should be under Advanced Tab, Advanced settings section...
        You can file a support ticket here with NG and see if they can look into this:
        https://www.netgear.com/mynetgear/registration/login.aspx
