keylargo
Mar 22, 2020Aspirant
comparing different models
I'm trying to understand the difference between the Orbi models.
What's the difference between the RBK52W and the RBK23W.
And then how do those compare with the RBK43S (and what's the difference between the 43 and the 43S)?
Thank you.
this table goes over a lot of the different systems.
- keylargoAspirant
Thank you for the response. But I'm still unclear on the difference between the RBK52, the RBK23, and the RBK43.
The only big different between the 50 series and other series is the wifi back haul connection rates, 50 series use 1733Mpbs while all th rest use 866Mpbs.
keylargo wrote:Thank you for the response. But I'm still unclear on the difference between the RBK52, the RBK23, and the RBK43.
