romsweb's avatar
romsweb
loosing external access to my synology NAS daily
Hello Everyone,
I'm embarassed because I'm loosing external access to my synology NAS randomly (but once a day those last few days).
And the only thing that brings back my external access is to reboot my orbi (as we are confined at home, make my kids and wife angry :-( ).
When it's happening, direct access from my specific domain name or quickaccess do not works.
I've just changed my NAS but was doing the same to the last one from 2 months now.
At the beginning I though it was upnp, so I disabled it and ass port forwarding:
https://www.dropbox.com/s/qafvbr8q7w3tgxc/Capture%20d%E2%80%99%C3%A9cran%202021-10-02%20%C3%A0%2022.53.02.png?dl=0
it works fine for some times, then stopped again, I reboot my orbi, boom working again.
I tried to check everything: logs, circle, allowed devices list, my nas always here...
I really don't get what's the problem here on my orbi.
Hop someone will be able to help me.
Thanks everyone
Romain
  • CrimpOn's avatar
    CrimpOn
    Can you please report the firmware version on the RBR50?
      • CrimpOn's avatar
        CrimpOn
        Internet connections to Synology NAS have been the subject of several recent posts, especially regarding firmware V2.7.3.22.
        I do not recall much resolution except for 'downgrading' the Orbi firmware to a prior version. (I have no Synology NAS, so could not help much with the diagnosis.)  Might be worth reading through these posts:
        https://community.netgear.com/t5/Orbi/Dynamic-DNS-problems-on-Synnology-with-Orbi-RBR50V2-firmware-2-7/m-p/2139355
        https://community.netgear.com/t5/Orbi/Fundamental-bug-in-Orbi-STILL-has-not-been-fixed/m-p/2131508
        https://community.netgear.com/t5/Orbi/ORBI-Port-443-Closed-even-with-Port-Forwarding/m-p/2127494
        Downgrading Orbi firmware is a nightmare because with this latest firmware, Orbi's will 'auto-update' back to V2.3.7.22.  There are only two ways to prevent this, and both have drawbacks:
        • Use telnet to change a setting in the Orbi router, which lasts only until the router is rebooted. (I have one that remains downgraded after more than 4 weeks because it has never lost power.  If it does lose power, then I would have to go through the entire process of downgrading firmware and using telnet to block updates.  As Pooh would say, "Oh, bother".
        • Placing another router between the Orbi and the internet which will block access to Netgear's update sites. This requires another router (which many people have in their 'junk box', and also makes forwarding ports much more tedious. (possible, but tedious).
        Other users have mentioned finding comments on the Synology forums that describe this issue. I believe one mentioned there might be a difference between Synology's version 6 and version 7 operating system.
        Sorry not to have so little information to share.
