- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
orbi rbr50 no net or wifi when connected
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello all, hope the community can help, ive got NBN internet, it was working fine untill last week, long story short, telstra replaced all the hardware, now my wifi routers would not connect ethernet or wifi, i rang the phone company and done serveral test, they said the wifi router must be broken so i went out and bought the orbi rbs20, it would not still connect to the net via the routers, ive have tried everything i can think of, but when i connect the pc directly to the nbn modem the internet works fine, can somebody please help, i have called the phone company and have spoken to them for serveral hours and still could not solve this problem,
thanks in advance
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: orbi rbr50 no net or wifi when connected
What is the Mfr and model# of the ISP modem the NG router is connected too? Built in router here? If so, This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
1. Configure the modem for transparent bridge mode. Then use the Orbi router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly.
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
Try option #3...
@VStarNinja wrote:Hello all, hope the community can help, ive got NBN internet, it was working fine untill last week, long story short, telstra replaced all the hardware, now my wifi routers would not connect ethernet or wifi, i rang the phone company and done serveral test, they said the wifi router must be broken so i went out and bought the orbi rbs20, it would not still connect to the net via the routers, ive have tried everything i can think of, but when i connect the pc directly to the nbn modem the internet works fine, can somebody please help, i have called the phone company and have spoken to them for serveral hours and still could not solve this problem,
thanks in advance
- Mark as New
- Bookmark
- Subscribe
- Permalink
sorry i dont know what firmware is on it, how do i find out?
i cant see any mfr, but the model is WNTD-CLI2
revision: R1D
the serial is 2.11.5323.180705
NTD UNI-CLIENT
there is no button on the NBN box, its connected directly to the satterlite disc, i cant disable wifi, it has 4 uni-d ports, port no1 is connected to my pc, with flashing green light at the port, port no2 is connected to orbi wifi router with no green light,
i tried to log into netgear but they said iam not connected to orbi wifi
i just rang telstra and ask them to bridge but they said they can only do it for telstra modems,
sorry iam a noob, i have tooken lots of photos but i dont have net on my phone to upload them on here
- Mark as New
- Bookmark
- Subscribe
- Permalink
What happens if you connect the Orbi to port 1 instead of the PC (and maybe restart the modem so that it recognizes a new MAC address)?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Modem Combo Units:
Couple of options,
Try option #3...
The ISP modem needs to have it's wifi disabled if at all possible. Ask your ISP to help you with this.
@VStarNinja wrote:sorry i dont know what firmware is on it, how do i find out?
revision: R1D
NTD UNI-CLIENT
- Mark as New
- Bookmark
- Subscribe
- Permalink
i went and bought a telstra modem, it seems to work when i wired it directly to the ethernet port on the orbi but doesnt work when its in the internet port, my phones and tv has wifi accept for the laptop, its connected directly to a lan port on the telstra modem, i tryed to switch to wifi so i can log in netgear but its not working, ive dl the netgear app but it says incorrect wifi mobile router, this router is not supported by netgear app, i have loged in the past with my laptop to block some device from using my wifi but cant seem to do it now, keeps telling me to connect to the orbi wifi network
- Mark as New
- Bookmark
- Subscribe
- Permalink
do i need a ethernet splitter? befor i had the cable connected to the orbi wifi roucter via the internet port, then a cable from the ethernet port on the wifi to my pc, i could log in then, should i buy a ethernet spitter? spit from my pc, 1 cable to modem and the other to wifi router internet port?
- Mark as New
- Bookmark
- Subscribe
- Permalink
The isp modem connection needs to be conected to the Yellow internet port on the RBR. Even in AP mode.
What is the model# of the new modem?
- Mark as New
- Bookmark
- Subscribe
- Permalink
sorry to waste you guys time, i solved the problem, i play abit of online games and trying to reduce the lag, i connected my pc direcly to the modem but i get no net, so i connected the pc to the orbi router via ethernet, the internet port is connected to the modem, i can log in now and block certain wifi users, i want to slow certain deviced but cant seem to do it, iam in Qos setup but its only showing me internet test, does anybody know how to do it? or should i just start a new topic?
- Mark as New
- Bookmark
- Subscribe
- Permalink
QoS on Orbi is all automatic and mostly a Basic QoS from what I gather. Orbi doesn't have a more granual QoS UI for users to make configurations.
