tmittelstaedt
Jun 26, 2021Star
Bad update on 8 port Gs108eV3
Thought I would ask and possibly warn people about this.
I have a GS108Ev3 on the bench. It was in use for about 2 years. I attempted to update it with the latest firmware off the Netgear website using Chrome. The switch went into firmware upload mode fine, it took the upload file. Then I got a browser error that the switch was no longer communicating.
I can pin reset it, and it reverts to the 192.168.0.209 ip number. But any attempt to access it with a web browser and no joy. I also tried accessing it with the ProSafe utility and that utility sees it but says it must be configured with a web browser.
So I guess the latest firmware is designed to take a managed switch and turn it into an unmanaged switch. /s
Any suggestions on recovery?
- DaneANETGEAR Employee Retired
Welcome to the community! :)
Kindly try to disconnect the GS108Ev3 from your existing network. Then, connect a PC/laptop directly a LAN port of it. Try to access its web-GUI using its default IP Address which is 192.168.0.239. You can also check if you can get replies when you ping the default IP Address of your GS108Ev3.
DaneA
NETGEAR Community Team
That is what "I have the switch on the bench" means.
Bench testing means completely disconnected from the network and on a workbench. Please add this term to your
vocabulary. Here is an explanation: https://en.wikipedia.org/wiki/Test_bench
That is implied by "bench testing"
I already said in my post that I had tried this on the bench
I do get replies from it when it's on the bench. As I stated already in my original post Prosafe connects to it which would
not be possible if the IP stack was not working at all. But the web GUI does not come up when attempting to access
with a web browser.
Recent Smart Managed Plus update switch IP stack seems to be cumbersome on the MTU - double check if there is an MTU lower than 1500 is in place on the Web browser host.
Please provide more details (e.g. the original and the current updated firmware version) if you like to bring up any kind of "warning".
- BockemanAspirant
tmittelstaedt Thank you very much for politely and informatively exposing this problem and for your clear warnings. Bravo.
I too ran into problems when I upgraded one of my GS108Ev3 switches (from V2.06.03 to V2.06.24). I had been experimenting with VLAN and was getting some unexpected behaviour, so an upgrade seemed the obvious thing to try.
The documentation appears to suggest that following the upgrade, the GS108Ev3 switch would reboot itself. But I was left with web page still showing the "Transfer Status" with the progress bar filled 100% for half-an-hour.
I would expect at least "after 5 minutes then refresh the page ..." or whatever.
And when this is fixed, then "Tranferring" could be corrected to "Transferring".So despite the warning not to, I did everything the above instructions tell me not to do. But I could not get access to the device UI.
tmittelstaedt wrote:As it turned out, yes this was the problem. Unknown to me the MTU on the Ethernet interface on my laptop was set to 1300."
Ditto (on my desktop)!
Days later and after much consternation, I came across your warning. I fixed the MTU on my desktop following your instructions. I now have web access via the device UI.
It's almost a wonder Netgear engineering managed to implement a very simple IPv4 stack on the 8051-class Micro-Controller along with the still available NSDP. This does also not allow a sophisticated Web UI implementation. The limitations were discussed and explained several times already:
- no PMTUD (Path MTU Discovery), only he default 1500
- no frames different from the default standard 1500 (== no config access over VPNs or similar)
- no tagged VLANs for the configuration management (neither in the WebUI nor in the NSDP)
