Boatguy54's avatar
Dec 22, 2017
GS108Ev3 POE pass thru?
If I put a GS108Ev3 switch downstream from a switch that provides POE, will the GS108Ev3 pass that power through to a connected device?
Or does the POE have to be injected at the last switch before the device?
  • Hi,
    The GS108E doesn´t have PoE Passthrough capabilities and can´t be powered by another PoE device or pass this power to other devices.
    However we do have our GS105PE that works exactly like this, you can power it from another PoE switch and at the same time is able to pass this power to a couple of devices. My recommendation would be that you use a PoE+ switch so you will have enough power to power other devices.
    Hope it helps!
    Xavier Lleixa
    NETGEAR CBU PLM
1 Reply
  • XavierLL's avatar
    XavierLL
    NETGEAR Employee Retired
    Hi,
    Hope it helps!
    Xavier Lleixa
    NETGEAR CBU PLM
ProSupport for Business
