cloud3648's avatar
cloud3648
Follower
Jun 28, 2021
GS324TP S350 fan turns on at boot up then turns off minutes later 1.0.0.34
I just noticed that The fan does not stay on like it used to when a poe device is plugged in. So i rebooted the switch. When the switch boots up, the fan turns on for about a min then its it turns off. In teh dashboard the temps ate about 47c and the fans are set to off. My firmware version is 1.0.0.34.
Is this normal behavior or is something wrong with the switch?
ProSupport for Business
