OlafE
May 09, 2019Tutor
Memory log flooded on stacked S3300-52X ProSAFE 48-Port Gigabit Stackable Smart Switch
Hello,
the memory log is flooded every two seconds with the same message:
With the help of Netgear support could be determined, that the error messages seemed to be related to one of the SFP ports of one of the switches (without further details, which switch or which port). Since these ports where involved in the stacks ring topology I found that two ports of the SFP ports did show offline.
After I could someone onsite to check/replace the cable, the missing ports flashed online and the error message disappeard. So we had basically a broken ring with a less than sufficient error message tied to this.
Best greetings from Germany
Olaf
- OlafETutor
Additional info: The stack consists out of 3 devices, the firmware is the latest available (
- DaneANETGEAR Employee Retired
Hi OlafE,
Welcome to the community! :)
Kindly answer the questions below:
a. Are there any recent changes made in the settings of the S3300-52X switch stack?
b. Are there any recent changes made in the network setup where the S3300-52X switch stack is deployed?
c. Is the S3300-52X switch stack still working fine even though the memory log is flooded with the logs you are seeing?
d. What devices are directly connected to the S3300-52X switch stack?
e. How is everything connected? It would be best if you post an image of your detailed network setup.
f. Are there VLANs configured on the S3300-52X switch stack?
DaneA
NETGEAR Community Team
- OlafETutor
Olaf
