Chris__B's avatar
Chris__B
Multicast KVM over IP (Geffen 4K) works on GS105 switch but not on GS110TP
I have a transmitter and receiver pair of KVM Extender over IP from Geffen that use multicast.
When the Tx and Rx are plugged back-to-back, they work fine.  Proper operation: once making the final wired connection, the receiver will display on screen that it's "Searching for server", then in a second or two will say "Waiting for video..." and then a split second later the remote screen is up.  Sometimes too fast to see "Waiting for video..."
Both plugged in to GS105 switch, they likewise work fine.  Exact same behavior as when plugged back-to-back.
Both plugged in to GS110TP, doesn't work.  When making the final connection, the receiver will display on screen that it's searching for server, then in a moment say "Waiting for video..." and stick here forever, or, rarely, paint the screen with garbage.
Seems odd that the nicer and more expensive switch chokes off the connection.  Auto Video, IGMP snooping and flood control are disabled.  The Receiver's Ethernet activity LED blinks feverishly in concert with the Transmitter's activity LED as if some but not all packets are making the trip, but I'm not sure about that.
The goal is to plug the Tx server into a GS110TP tied via fiber to another GS110TP having the Rx remote station.  Sadly I didn't get to that step yet since it doesn't work on a single switch.
Thanks for any tips,
Chris
  • Chris__B wrote:
    But now shopping for a different solution since it requires jumbo frames.
    Well, that's not a Netgear problem. Can't see any reasons for not enabling Jumbo Frames on a modern home, SOHO, or Small Business Layer 2 LAN.
    Pushing either of FullHD (HDMI plus some additional data channels) over Gigabit requires compression and a very healthy GbE network, pushing 4K UHD over a Gigabit network is almost impossible without heavy compression and massive frame loss. Most vendors have similar requirements, even the leading edge ZeeVee ZyPerUHD does require IGMP multicast snooping and Jumbo Frames of at least 8000 - when transmitting a 4K stream they take up about 400 Mb/s bandwidth - with massive compression, with frame loss and ways off correct sync HDMI transmission.
    Two non-compressed, no frame loss 4K video streams are oversubscribing the bandwidth available on a 10GbE link. That's why AV pros are going towards SDVoE on at least 10G (for a single HDMI) or with switch embedded HDMI for uncompressed, almost latency free 4K/UHD or HDR content distribution. Check out Netgear SDVoE offerings paired with ZeeVee ZyPer4K encoders, decoders, and embedded switch HDMI ports. Thic can't be cheap.
  • schumaku's avatar
    schumaku
    Chris,
    These devices can be configured to use Unicast or Multicast. In Multicast mode (the preferred one, certainly if multiple connections or receivers are up) is Multicast.
    From the 4K Ultra HD HDMI and VGA KVM over IP – Sender unit - Resources : EXT-UHDV-KA-LANS-TX Manual, p.V:
    Important
    • When connecting through a Local Area Network, a managed gigabit switch is required. Jumbo Frame Support (8k or greater) and IGMP Snooping must be enabled.
    • A dedicated LAN is not required but highly recommended.
    • When using HDCP-encrypted content, only the HDMI inputs and outputs can accept and display the content.
    • We recommend that Sender and Receiver are first connected directly and functionality/performance is fully verified before integrating them into a Local Area Network.
    Note: Operating ICMP multicast on a non-managed switch, Ethernet bridge, Wireless AP, ... does lead to all multicast traffic flowing out all ports, and not just the one towards the receiver. That's why the vendor does require a managed switch - so IGMP snooping can be configured for the VLAN where the KVM is connected to.
    You can try to block unknown multicast - if this does block the KVM multicast traffic, disable the unknown multicast blocking.
    Not a Netgear switch issue at all...
    -Kurt.
    • Chris__B's avatar
      Chris__B
      Thanks, I'll try turning on IGMP and snooping, and jumbo frames.  But now shopping for a different solution since it requires jumbo frames.
      • schumaku's avatar
        schumaku
ProSupport for Business
