rzulian
Jun 12, 2022Follower
Netgear GS752TP keeps rebooting
I've started a reboot from the web interface.
Now the switch seems to keep continuously rebooting. I cannot connect to it, nor I can discover it in the network. I've tried to restore to factory default, but I'm getting the same results. One note about the connection from the computer to the switch. The led turn on, but it doesn't start blinking. And after a while it turn off.
What can I do?
Thanks!
1 Reply
- DaneANETGEAR Employee Retired
Welcome to the community! 🙂
I suggest you to open a support ticket with the NETGEAR Support Team here at anytime for a hardware check. Let them know also the troubleshooting steps you did so far. If your GS752TP has been proven to faulty, be ready to upload a soft copy of its Proof of Purchase for warranty verification. If the hardware warranty is still valid, an online replacement will be processed.
DaneA
NETGEAR Community Team
