PaulBush
May 08, 2021Aspirant
Simple VLAN Setup
I would like to setup what I would think would be a simple wired 2 VLAN setup. One VLAN for all my home devices and one VLAN for my work computer. I would like them to not have access to each other or even see each other but both have access to the internet through my cable internet connection. Is this possible? I've setup the 2nd VLAN but I can't seem to get internet access working. In searching these forums it appears I may need a VLAN aware/capable router. Was hoping all the features I needed were in the switch.
My equimpment:
Internet -> Cable Modem -> Asus RT-AC88U wifi router -> Netgear GS324TP switch -> work computer, home computer, etc...
Any help greatly appreciated :)
Paul
- DaneANETGEAR Employee Retired
Welcome to the community! :)
Yes, you will need a VLAN-aware router that will serve as DHCP server to the VLANs you have configured to the GS324TP. The GS324TP does NOT have the capability to provide DHCP service since it is a Layer 2 switch.
Here is an example of the setup that you need. Let me share the article below and use it as your guide:
How do I set up one or more VLANs between a NETGEAR ProSAFE firewall and a smart switch?
DaneA
NETGEAR Community Team
- PaulBushAspirant
Thank you very much for your help.
