Orbi WiFi 7 RBE973
Smart Control Center does not discover Prosafe GS724T v3 switch - cannot update firmware
bass1
Tutor
I have a GS724Tv3 switch and are trying to connect to Smart Control Center. Discovery fails to detect. I wish to upgrade firmware which I understand needs to be done from SCC, web login does not offer this option...
Based on research & troubleshooting so far I can advise:
  • PC running SCC is connected directly to the GS724t. The GS724t is then connected to my internet gateway
  • The switch and PC IP settings are correct, being on the same subnet, have same subnet mask and gateway.
  • I can access the internet from the PC
  • I can log into the switch from a browser on the PC and check or change any settings
  • The switch is running Boot Version 5.0.3.2 and Software Version 4.2.1.5
  • The PC is running W10 Pro x64
  • In case of firewall blocking SCC access to the switch I have turned Kaspersky firewall off.
  • If I run the command    netsh advfirewall show allprofiles    all profiles have state = OFF
I've run out of ideas at this point. What next?
Model: GS724T|24-port Gigabit Smart Switch
Message 1 of 3
Accepted Solutions
bass1
Tutor
Re: Smart Control Center does not discover Prosafe GS724T v3 switch - cannot update firmware
Problem sorted.
I worked out I could upgrade firmware by browser so upgraded from 4.2.1.5 to 5.0.5.4.
Switch is now discoverable in SCC.
Am now in process of going to latest fw 5.4.2.30
Cheers
Message 3 of 3
All Replies
bass1
Tutor
Also add to my list, I have tried a factory rest as well
Message 2 of 3
bass1
Tutor
Problem sorted.
Cheers
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 5239 views
  • 1 kudo
  • 1 in conversation
Announcements
