boboaung
Dec 07, 2023Follower
compatible netgear switch for Crestron Crestron DM-NVX-E30/D30
I would like to seek a recommendation which switch is compatible with Crestron DM-NVX-E30/D30 among the two switch below.
Netgear GS752TP-200EUS 48-port gigabit network switch with POE
Netgear GS324TP-100EUS 24-port gigabit network switch with POE
Thanks in advance.
1 Reply
You won't have any luck and success deploying unmanaged or just Smart Managed switches for a Crestron installation.
Look into the Managed Switches section, with Fully Managed AV switches like the M4250 for 1G, or M4350 with faster MultiGig switches.
Don't hesitate to contact the Netgear Pro AV Design Services team for free design support and implementation assistance for AV networks on any scale. Strongly encouraged - they do a brilliant job!
