Orbi WiFi 7 RBE973
Reply
smart poe switch closing down ports
nicke20
I recently bought the above switch to make my home network a bit neater, has a router going in and a ubiquiti cloud key plugged in running 4 wireless ap's it then has a bout 10 devices plugged directly in and 3 ports going off to un managed switches with the ussual stuff hanging off those, wirelass ap's computers, cameras etc. My old system was two unmanaged 8 port gigabit switches daisy chained together and poe injectors where needed. Now im having problems, i can plug almost everything in but when i come to the last two ethernet cables both going to switches with multiple devices attachedI plug one in ok, but as i plug the second in the first one all the lights on the port go off at both ends??
all cables are ok, I have checked all ip addresses (37 of them) and none conflict that i can find. I have switched off all the meshing on the wireless ap's (each switch had a wireles ap on it.
Ideas please for a none network gurus
is there a feedback loop?, how do i find / stop it?
many thanks, nick
Oh i updated the firmware to the latest (took 4 or 5 seperate updates to do)
Model: GS724TPv2|24-Port Gigabit Ethernet PoE+ Smart Managed Pro Switch with 2 SFP Ports
Message 1 of 5
Accepted Solutions
schumaku
Guru
Re: smart poe switch closing down ports
Tha'ts the classic Sonos STP/l2 loop issue - if all Sonos players are wired, disable WiFi...
FWIW: The L2 loop existed before on your unmanaged switches - but you have never realized there is a problem and the network failed to perform well.
Message 4 of 5
All Replies
nicke20
Bit more info
going into the gui, it is reorting a level2 loop
now port 8 on the config page is showing as diasbled and port 17 as enabled
If i re enable port 8 admin mode then port 17 drops out and vice versa
the topology hasnt changed from my pre non managed switch days
can the loop be wirelessly?
could it be from the sonos system?
AFAIK i have no physical wired loop
Message 2 of 5
nicke20
Im hoping i have cured my L2 loop myself
sonos play 1 wired and picking up wifi, one from one branch of main switch one from another
ill look at it all againn tommorow
Message 3 of 5
schumaku
Guru
Message 4 of 5
nicke20
every day is a school day
thank you for confirming and giving a propper explanation to what i had found by the good old method of plug one thing in at a time till it falls over!
Thank you
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 2049 views
  • 0 kudos
  • 2 in conversation
Announcements
