Dazman9
Jun 01, 2021Follower
PLP1000 Compatibility with PLW1010 (or other wireless model)
Hey there, I live in an old house with thick brick walls where I stuggle to get a wifi signal in rooms more than one room away from the wifi box. I have a few PLP1000 ethernet adapters which work just great for my son's Playstation and PC up stairs, but I'd also like to get wifi at the back of the house, upstairs and in the garden. Is the PLW1010 (or other powerline Netgear wifi product) compatible with the PLP1000 on the same power loop? If not are there any Netgear products which are.
Thanks, Darryl.
As plemans says, it will work. But things to bear in mind:
- you can't buy the wifi (AP) bit on its own from Netgear, only the two-plug bundle
- Powerline is an industry standard, so you could add a different brand of AP plug to your existing network
- if you do buy the bundle, you need just one plug connected to the router
Remember, when adding new plugs to an existing network, you need to follow this advice:
>>> Adding a powerline adapter to an existing powerline network <<<
Another way to achieve what you want is not to buy the two-plug bundle with AP combined but to use a standard remote plug as the wired connection to a standard extender/access point. In this way you could get a remote wifi source that is more powerful than the bundled plug. I have an Orbi router (in AP mode) at the "remote" end of a Powerline network.
Yes it is compatible and will work
