Flappy_asdf's avatar
Flappy_asdf
Follower
Jun 01, 2020
POWERLINE ADAPTER NOT WORKING AND NEEDS FIRMMWARE UDPATE I CANNOT FIND IT
I have looked around and cannot find the firmware update for this model, it does not work and I cannot connect to any devices as it does not give an ethernet connection. I need to update the firmware but cannot find it I need help.
  • plemans's avatar
    just because it doesn't work doesn't mean its a firmware issue.
    what are the led's on it doing?
    have you tried connecting them on the same circuit?
    Many things influence powerline and can make it incompatible with a home or work poorly at times. these include:
    arc fault breakers
    gfci outlets
    surge protectors
    high draw appliances
    poorly made electronics
    some cell phone chargers
    or even electronics going bad.
    old/poorly done wiring
    I'd recommend hooking them on the same electrical circuit to see if they connect. Thats the easiest way to check them. It doesn't mean that they aren't working if they won't connect, it could still be the wiring/interference. But it would give you the least interference if something is injecting feedback into the powerline.
  • michaelkenward's avatar
    michaelkenward
    Powerline technology isn't the same as routers. It is essentially a bit of wire.
    Firmware is mostly there for plugs with wifi.
    Apart from that it is "dumb" technology. Plug it in  and it should work. If not, something else is happening. See what plemans says.
    If you want more advice, tell us a bit about what is happening at your end.
    Take this comment:
    Flappy_asdf wrote:
    ...it does not work and I cannot connect to any devices as it does not give an ethernet connection.
    We need a bit more than "it does not work".
    What are you doing and where does it go wrong?
    Here at least, PL1000s were a doddle. Plug into router, then plug into remote socket, attach access point, bingo. I had to do nothing else.
