Paulus101
Feb 16, 2017Follower
Can I use a XAV2601 with 2 XAV1004 ?
I have 2 places i need multiple ports for tv, satbox, stereo ....
can i connect the XAV2601 to my router and take out ethernet 2 differert places with 2 * XAV1004 ?
will that setup work ?
1 Reply
As the manuals put it:
"Different Powerline adapter models can share the network. All Powerline NETGEAR AV products (models XAV101, XAV1004, XAV2001, XAV2501, and XAVN2001) are compatible."
There is a manual here:
XAV1004 | Product | Support | NETGEAR
If you have the plugs try it. If you don't they are End of Life.
You can usually add new powerline devices to an existing network, but you have to follow the instructions to get them to talk to the existing plugs.
