- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
PLP2000 no Pick a Plug light
- Mark as New
- Bookmark
- Subscribe
- Permalink
Bought a pair of these Powerline 2000 units to extend service into a bedroom/den where WiFi signal is weak. Set them up plugged directly into outlets, got Power and Ethernet lights (Modem and PC) but no Pick a Plug lights. Pressed the factory reset buttons on both units multiple times (including holding them for 10-15 seconds), moved them both to outlets on the same wall with nothing else plugged in -- nothing. There is no firmware for these boxes (no CD came with them either) and the only troubleshooting tips are 1) reset the boxes to factory settings (tried multiple times) or 2) "make sure that all Powerline devices are using the same encryption key" -- I didn't change any settings and it's not clear how to even if I wanted to. Any thoughts?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: PLP2000 no Pick a Plug light
You'll find documention for your PLP2000 here: https://www.netgear.com/support/product/plp2000.aspx#docs
Page 10-11 of the user manual describes how to reset the encryption key. http://www.downloads.netgear.com/files/GDC/PLP2000/PLP2000_UM_EN.pdf
- Mark as New
- Bookmark
- Subscribe
- Permalink
The lack of Pick a Plug lights is a sign that they aren't talking to each other over the mains circuit.
Could be duds.
