MPProd's avatar
MPProd
Follower
Jun 06, 2024
IntervLAN between two M4250 switches
Hi all,
New to all the Netgear AVLine switches and trying to figure out how everything works.
What I am trying to do is setup a 2 switch-config where I have a Management VLAN (ID 1), Video VLAN (for NDI, ID 10) and Dante-audio VLAN (ID 20). So far so good.
I followed the Youtube videos by Netgear to setup the VLANs. On the main switch (which is the M4250-10G2F-PoE+) I enable the DHCP server on all the 3 VLANS. On the other switch (M4250-10G2XF-PoE++) I added the VLANS and set them up as DHCP clients.
That is working, as well.
Now, what is not working is: I have a PC connected to a port in the management-VLAN and I want to run Dante Controller on that, be able to access config-pages of the PTZ cameras and so on. But I cannot access these things from the PC. I can't ping the devices in the other VLAN's. So I must be doing something wrong, although in one of the Netgear youtube-videos which I followed, Netgear showed that it has to be able to ping devices when the subnetmask and gateway are configured correctly. I checked that, and it seems I have it configured correct (the same as in the video).
I am a bit at a loss here, so hopefully someone on this community can help me with this.
Thanks!
Kind regards,
Marc
1 Reply
  • ErwinL's avatar
    ErwinL
    NETGEAR Moderator
    Hello MPProd
    And welcome to the NETGEAR Community! 🙂
    Can you provide the following questions below:
    1. Subnets for all your VLANs?
    2. Port members for each VLANs?
    3. PVID of each port members?
    4. What are the tag ports and untagged ports of the switch?
    5. Where is the DHCP server for each VLANs?
    Have a lovely day,
    Erwin
    Netgear Team
Master AV-over-IP networking, multicast protocols, and troubleshooting to confidently deploy and manage AV networks.
ProSupport for Business
