AgentANGST-4043's avatar
Mar 22, 2018
Change credentials on transmission addon - OS6
EDIT:  Per AgentANGST-4043's second post, this procedure doesn't work.
I wanted to change the credentials on transmission, as the default credentials are admin // admin and It makes me feel a bit uneasy. This is running on my Readynas 102, on 6.9.3
1st stop the service:
/etc/init.d/transmission stop
(the service is called "transmission" and not "transmission-daemon" like most ones found out there in linuxland)
2nd - Find settings.json
root@my-nas:/# find . -name settings.json
./data/Transmission/config/settings.json
(found it !!)
3rd - edit the file, remove the hashed password and put in a new one in clear text
root@my-nas:/# nano /data/Transmission/config/settings.json
Then verify that it is changed and saved.
root@my-nas:/# cat /data/Transmission/config/settings.json | grep password
"rpc-password": "lalala",
4th - Start trasmission again:
/etc/init.d/transmission start
That should do the trick
BONUS!!
If you want to use nano to edit the settings.json file you will have to install it first:
run these two commands:
apt-get update
apt-get install nano
Enjoy!
1 Reply
  • Obviously that does not work, but netgear will not let me edit the first message.
    Tried killing the process, using transmission-daemon --password xxxx to change the password....
    But on process reload the password is set again to the "admin" default.
    Quite frustrating, as I've tried a lot of things and nothing seems to work.
    Can you help me get this password changed?
ProSupport for Business
