TheBigZ's avatar
TheBigZ
OpenVPN Client Configuration for PIA on ReadyNAS 102
Hi All, I have been trawling the inter-webs to get help with my issue below. I am hoping someone here will be my savior. I have tried OpenVPN and PIA forums, but no love.
I have a readynas 102 I want to put behind a VPN provided by Private Internet Access. I followed the following thread to install and configure and it was working great. To get it running at startup I think I used the "update-rc.d startvpn.sh defaults" option because the crontab file doesn't seem to be used on the readynas for some reason. I left the command in the crontab anyway I think.
http://www.readynas.com/forum/viewtopic.php?f=11&t=78455
About a week ago I logged into transmission and files were coming down super slow, if at all, and dropped into the "error" bucket of torrents. I putty'd in and opened lynx to see if the NAS had internet access. That seems to vary. Sometimes it works sometimes not. I tried turning off and on again a few times to restart the service but the problem persists. I even tried starting manually. this is what I get...
root@BigBaller:/etc/openvpn# openvpn AUSydney.ovpn
Thu Apr 30 19:07:31 2015 OpenVPN 2.2.1 arm-linux-gnueabi [SSL] [LZO2] [EPOLL] [PKCS11] [eurephia] [MH] [PF_INET6] [IPv6 payload 20110424-2 (2.2RC2)] built on Dec 1 2014
Thu Apr 30 19:07:31 2015 WARNING: file 'userpass.file' is group or others accessible
Thu Apr 30 19:07:31 2015 NOTE: OpenVPN 2.1 requires '--script-security 2' or higher to call user-defined scripts or executables
Thu Apr 30 19:07:31 2015 LZO compression initialized
Thu Apr 30 19:07:31 2015 RESOLVE: NOTE: aus.privateinternetaccess.com resolves to 4 addresses
Thu Apr 30 19:07:31 2015 UDPv4 link local: [undef]
Thu Apr 30 19:07:31 2015 UDPv4 link remote: [AF_INET]108.61.96.10:1194
Thu Apr 30 19:07:31 2015 WARNING: this configuration may cache passwords in memory -- use the auth-nocache option to prevent this
Thu Apr 30 19:07:32 2015 [Private_Internet_Access] Peer Connection Initiated with [AF_INET]108.61.96.10:1194
Thu Apr 30 19:07:35 2015 TUN/TAP device tun0 opened
Thu Apr 30 19:07:35 2015 do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0
Thu Apr 30 19:07:35 2015 /sbin/ifconfig tun0 10.170.1.10 pointopoint 10.170.1.9 mtu 1500
Thu Apr 30 19:07:35 2015 Initialization Sequence Completed
and then it just sits there. I don't get my command prompt back so I stopped it and got
Thu Apr 30 19:18:26 2015 event_wait : Interrupted system call (code=4)
Thu Apr 30 19:18:26 2015 /sbin/ifconfig tun0 0.0.0.0
Thu Apr 30 19:18:26 2015 SIGINT[hard,] received, process exiting
ifconfig shows the tunnel is created. For some reason nothing seems to get to the outside world.
I'm not much of a command line warrior so any help on how to diagnose this better or any solution would be greatly appreciated.
Thanks.
ProSupport for Business
