BaJohn
Feb 02, 2016Virtuoso
PHPMyAdmin Installation help required.
I have Installed PHPMyAdmin Version 4.0.4 on my ReadyNAS by using the 'Poussin' application from the Apps page.
I am now undecided whether to update this to the latest Version, which I think is 4.5.4.1,
or get the current version working first, which requires creating 'config_inc.php' somewhere.
Since the config file needs doing sooner or later, I might as well do that first.
I have read lots of documents on this for that version 4.0.4 and the latest, both via the Netgear forum pages and elsewhere on the Internet.
Since the installation is specific to the ReadNAS, I am tended to use the ones that relate to that in preference.
Are there an CLEAR unambiguous instructions that would help me to configure PHPMyAdmin as I am confused from what I have read?
Just to be clear PHPMyAdmin has installed okay and it is the config file that I need to sort out.
