bbis's avatar
bbis
Follower
Dec 09, 2018
Readynas Aria2 Applications
Aria2 is a lightweight multi-protocol & multi-source command-line download utility. It supports HTTP/HTTPSFTPSFTPBitTorrent and Metalink. aria2 can be manipulated via built-in JSON-RPC and XML-RPC interfaces.
Update : 2018-12-8
  • Update Aria2c new version to 1.34.0
  • Update AriaNg version to 1.0.0
Support systems:
ReadyNAS 102 ReadyNAS 312 ReadyNAS 626X
ReadyNAS 104 ReadyNAS 314 ReadyNAS 628X
ReadyNAS 202 ReadyNAS 316 ReadyNAS 716X
ReadyNAS 204 ReadyNAS 422 ReadyNAS 2304
ReadyNAS 212 ReadyNAS 424 ReadyNAS 2312
ReadyNAS 214 ReadyNAS 426 ReadyNAS 3130
ReadyNAS 2120 ReadyNAS 428 ReadyNAS 3138
- ReadyNAS 516 ReadyNAS 3220
- ReadyNAS 524X ReadyNAS 4220
- ReadyNAS 526X ReadyNAS 3312
- ReadyNAS 528X ReadyNAS 4312
How install ?
1, download the installer ending in .deb
2, enter the ReadyNAS management interface, click into the application
3, choose to upload and install the application
Will,I‘m translating Chinese from Google translate.
Photo1: adds
Photo2: Login UI
Photo3: Aria2 conf Configuration UI
Web server AriaNG
Download:
https://github.com/iranee/readynas-aria2
ProSupport for Business
