tesstep
Feb 09, 2014Aspirant
Bittorrent Sync and ReadyNAS Duo v1
Hi,
I would like to have the confirmation that Bit Torrent Sync is not supported with ReadyNAS Duo v1 (Radiator 4.1.7 Sparc).
What is the issue? Is it the Linux kernel that is too old to support BT sync?
Thanks
/tesstep
Thanks
/tesstep
1 Reply
- fastfwdVirtuoso
tesstep wrote: Is it the Linux kernel that is too old to support BT sync?
No, the issue is that the BitTorrent Sync developers have not compiled their software for Sparc. And the software is proprietary, so no one else can compile it for Sparc, either.
