garyd9
Aug 14, 2015Virtuoso
iSCSi won't reconnect
I have a windows 2012 R2 Server running it's iSCSI initiator to a readyNAS (516, tested with both 6.2.4 and 6.3.5RC2) target. A single LUN is created in a single group. All encryption/authentication is turned off.
I can initially connect just fine normally, but when I shutdown/reboot the Windows Server, the Windows server is unable to reconnect to the iSCSI target when it comes back up from the reboot. The iSCSI initiator shows "reconnecting" but is just stuck like that and it won't reconnect. Deleting and recreating the configuration on the Windows side does no good - Windows iSCSI initiator is unable to reconnect (or connect) to the iSCSI target.
If I reboot the NAS, it reconnects.
A bit less drastic than rebooting the NAS, I can also use the NAS web interface to pull the LUN out of the target group, destroy the now empty group, create a new group, and put the LUN into the newly created group. Then, suddenly, windows will reconnect to the iSCSI target.
Obviously, having to manually intervene any time I do an auto reboot of the server is a royal PITA.
The readynas interface doesn't really show any iscsi related stats, so I have no idea what it THINKS might be going on that would block a reconnect. Windows event logs are almost as useless, showing only that it failed to reconnect.
Any help would be appreciated...
Thanks
Gary
- garyd9Virtuoso
It's a 1TB "thin" provisioned, and this has occured ever since it was newly created (firmware 6.2.4) and empty. Currently, it's at about 29% used. (728.9 GB free space.) The LUN options are currently set as: BitRot is ON. Compression is OFF. Snapshot is OFF. Sync is ALLOWED.
- mdgm-ntgrNETGEAR Employee Retired
What about if you instead use a thick LUN with bitrot protection and sync writes both disabled?
What is the capacity of your data volume and how full is this?
- garyd9Virtuoso
mdgm wrote:What about if you instead use a thick LUN with bitrot protection and sync writes both disabled?
I'll have to wait for the weekend to try it with a completely different LUN configuration. The overall data volume is something like 6 or 8 TB, but it's only around 50% full. (So, I do have the room to make this LUN thick.)
Mdgm, are these suggestions along the lines of "likely solutions", or more like "trying different things to see what might work"?
The reason I'm asking is that I'm suspecting, based on other threads on here of a similar nature, that the problem I'm seeing is related to the iSCSI software on the NAS not releasing the connection when the Windows Server reboots. If that's the case, then the target might be refusing the connection after a reboot as it thinks that the initiator is ALREADY connected. Is there some way, from SSH, to see what's going on from the NAS point of view? (ie: for example, something that might show "current list of connections" on the target?)
Ideally, even if I work around the problem by using a thick LUN (assuming that works around the problem), I'd still like to understand WHY I'm having the problem to begin with so that, perhaps, netgear can fix it (or I can report the issue to Microsoft if it's with their initiator.)
Gary
