menkelis's avatar
Oct 25, 2013
RNDP-600-100 Time to power on?
I just aquired a RNDP6000-100 and it takes aprox. 1.5 to 2 minutes after
turning on the "master" power switch before the unit starts up.
If I use the power button/frontview to shut down then use the front
power button, the unit starts up as I would normaly expect it to (fast).
I also have a NV+ (v1) and that unit powers up almost the moment the switch
is turned on.
So Is there something wrong with the RNDP-600 unit?
No RepliesBe the first to reply
ProSupport for Business
