chucksg
May 24, 2013Aspirant
How to port forward
I have a Netgear Prosafe FVS388. I'm trying to set up port 80 for our cameras. Nothing I have done works.
My router does not have port forwarding but port triggering, so is that the same as port forwarding? Is there step by step instructions anywhere or a tutorial that I can watch?
Thanks
Thanks
- chucksgAspirantin the LAN WAN Rules example you sent me there, a lot of services running.
For port 80 I need to use HTTP I think. Http should allow port 80 to open? - jmizoguchiVirtuosohttp is 80 as basic
- chucksgAspirantAfter checking no ports are open. How do I open any port on the prosafe router?
- jmizoguchiVirtuosoURL is exact place you create INBOUND rules
you have to have public IP on WAN of the FVS in order to any rules to work
