CorvieBat's avatar
CorvieBat
Can't log into my router, incorrect password
I'm having trouble logging into my router, every time it gives me an error saying my password is incorrect. Every time I go to log in on my browser on my computer, it doesn't even indicate it's connected to my router. I can't change the password anywhere and I already tired factor resetting it and it didn't do anything to fix it.
  • michaelkenward's avatar
    michaelkenward
    Is this with a web browser and the graphical user interface (GUI)?
    What address are you using?
    How do I log in to my NETGEAR wireless router? | Answer | NETGEAR Support
    I don't follow that. How is it any different from the first sentence?
    What happens when you reset and aim the browser at the router?
    What firmware version do you have on the device?
    A number is more useful than "the latest". There may be newer versions, or "hot fixes", that do not show up if you check for new firmware in the browser interface.
    If there is one it might also help if you told people the make and model number of the modem/gateway/ONT that sits between this router and the Internet. Is it, by any chance, also a router, with a set of LAN ports on the back?
    I ask because a lot of people turn up here trying to put a router behind a modem that is also a router. That can complicate troubleshooting.
    • CorvieBat's avatar
      CorvieBat
      I used both the routerlogin.net and routerlogin.com on my web browser. I've tried Oprea GX, Edge, Chrome, and Firefox and nothing prompted me to log into and it doesn't give me the option to change my password.
      michaelkenward I don't follow that. How is it any different from the first sentence?
      I meant more that it wasn't showing any interface that would allow me to change my password. Apologies I was very upset last night.
      I'm unsure what firmware it's on right now as I don't know how to check it.
      You're indicating that it's a second router yes? Which it is, it's not my primary router as I have another router that is my main router which is an Arris router, model number for it is a NVG4688MQ. It does have LAN Ports on the back.
        michaelkenward
        Trouble waiting to happen.
        That model number leaves Mr Google baffled. No results.
        But your description suggests that you are piling router on router. Bad idea.
        Two routers on your network can cause headaches. For example, you can end up with local problems with address on your network. Among other things, the other router can misdirect addresses that the Netgear router usually handles, such as routerlogin.net or the usual default IP address for a router, 192.168.1.1.
        This explains some of the other drawbacks.
        What is Double NAT? | Answer | NETGEAR Support
        Unless you have specific reasons for using two routers – to create two separate networks for example – it is often easier to use just one router and then to set up the second router as a wifi access point (AP) with a wired connection to the main router. Netgear advises this, as does just about every site you will visit.
        But that has its own drawbacks:
        Disabled Features on the Router when set to AP Mode | Answer | NETGEAR Support
        Most of that stuff then ends up in the hands of your main router.
        Would that prevent you from using the R6400 to do anything important?
  • FURRYe38's avatar
    Wire connect a PC to the router and factory reset the router using the back push pin button. Hold it in for 10 seconds then let go. Then log in to routerlogin.com or 192.168.1.1 using a wired PC and web browser and walk thru the setup wizard. Be sure write down all important information for safe keeping later on.
    https://kb.netgear.com/9665/How-do-I-perform-a-factory-reset-on-my-NETGEAR-router
    https://kb.netgear.com/22697/How-do-I-install-my-NETGEAR-router-using-the-router-web-interface
      CorvieBat
      I've tried both methods, nothing worked liked I mentioned in my earlier replies.
      • FURRYe38's avatar
        So with the Router disconnected from everything accept one wired PC and pressing the reset button for 10 seconds and release, giving 1 minute, does the wired PC not get a 192.168.1.something address and you can't get anything to pull up in a web browser at 192.168.1.1?
