Dolomiti99
Oct 04, 2023Follower
Compatibility Araknis Access Points
Just purchased a nearly new townhome 1900 sqft 2 floors. Home has an araknis router and 2 araknis access points. Araknis is currently controlled by an alarm integrator using OVRC.
My netgear router is actually 6250 not 6260 ( 6250 not listed in forum menu).
If I remove the araknis router, will this netgear router ( or an updated version) be able to work well with the existing ceiling mounted araknis access points? Is there any complicated configuration to do that if it does? Thanks for your advice.
Since NG isn't the Mfr of Araknis products, only way to tell is to try it and find out and something to ask Araknis about as well since i'ts there product.
Check here for previous references to this brand:
Search - NETGEAR Communities – Araknis
My netgear router is actually 6250 not 6260 ( 6250 not listed in forum menu).Probably the R6250, or possibly the R6250v2.
