dbell45
Aug 22, 2016Aspirant
Disable wireless radios
Can someone tell me how to disable the wireless radios on a WNDR4300 router? The information I've been able to find says to uncheck the "enable wireless radio" button for both frequencies but I can't find that setting. Under Advanced>Wireless>Wireless Setup there are check boxes for "Enable SSID Broadcast", but not "Enable wireless radio". Does disabling the SSID broadcast turn off the radio? Thanks.
- Retired_Member
Wrong Menu
- dbell45Aspirant
Thank you very much.
- Retired_Member
You're welcome!
