× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
Firmware update R6400
Daddyo70
Initiate
It does not let me do the firmware update On the Netgear nighthawk app It says it does it but it goes back and it has the same version I don’t know what to do
Message 1 of 4
Guru
Re: Firmware update R6400
have you tried manually doing it with a pc?
https://kb.netgear.com/23960/How-do-I-manually-update-the-firmware-on-my-NETGEAR-router
what version are you currently on?
Current setup: CM2000-> RBE973S-> Trendnet TEG-S380-> GS716T-> pi-hole
also in AP setup: RAXE500->EAX80
1.4gig download/100mbps upload from Xfinity
We’re members of the public helping out on our own time.
Message 2 of 4
Daddyo70
Initiate
V1.0.1.76 It tells me that it’s updating but I’ll go back it says The software was updated successfully but it goes back to the same thing
Message 3 of 4
Guru
did you try the manual update with a pc/laptop?
https://www.netgear.com/support/product/r6400#download
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 766 views
  • 1 kudo
  • 2 in conversation
Announcements
Orbi WiFi 7
