×  Introducing Nighthawk RS700 WiFi 7 (BE) Router. For more details, please visit Nighthawk Tri-Band WiFi 7 Router.
Reply
GS105E linked connection limited to 100M
Whitecro
Tutor
Hi
I have GS105E with 5 ports. Four of the ports are working at 1000 although the one connected downstairs to my router is only connected to 100M. I've checked with the manufacturer of the router and they confirmed its a 1000 ethernet port capable of carrying 1GB /s.
Does anyone know why this isnt doing 1000M?
Model: GS105Ev2|ProSafe Plus 5 ports switch
Message 1 of 6
Accepted Solutions
Whitecro
Tutor
Re: GS105E linked connection limited to 100M
Your a legend. It was the cable, my cable tester showed 1-8 good with the exception of no.7 not lighting up indicating a problem. Pulled it out of the wall and it was slighly nicked and hanging loose. I would have thought it would've killed the connection but no, it reduced it like you said to 100. Flying on 1000Mbps now although for some reason I cant see the switch IP address on my router. Maybe takes time to propagate.
Thanks!
Message 5 of 6
All Replies
Guru
If you move the cable from port 1 to port 2/3/4, does it connect at the same 100mbps on those ports? or does it connect at 1000mbps.
checking to see if its a port issue or an issue with the cable/router.
You could also try bringing the router next to the switch and connecting it with a known good cat 5E or greater cable.
Current setup: CM2000-> RBKE963B-> Trendnet TEG-S380-> GS716T-> pi-hole
also in AP setup: RAXE500->EAX80
1.4gig download/50mbps upload from Xfinity
We’re members of the public helping out on our own time.
Message 2 of 6
Whitecro
Tutor
Yes it does. I moved it from port 1 to 2 and still 100.Screen Shot 2021-08-10 at 11.05.32 pm.png
Message 3 of 6
Guru
So its not the switch.
Its either the cable you're connecting with or the router.
Easy rule out for the router is move it next to the switch (or the switch next to the router) and use a known high quality cable.
if it connects at gigabit speeds, then it'd be the cable you were using prior. If thats the case, you can try redoing the ends on the cable. A bad end can give you a 10/100mbps connection and not gigabit. Plus check the cable to ensure its at least cat 5e
Message 4 of 6
Whitecro
Tutor
Thanks!
Message 5 of 6
Guru
Glad it was an easy fix!
Message 6 of 6
Discussion stats
  • 5 replies
  • 1034 views
  • 2 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
