× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
How to install wireless router to AdTran equipment
goodguys
Hi,
CenturyLink completed the install of my dedicated T1 line in my home and have tested and verified internet access at the AdTran router.
I want to install my new Netgear wireless router now with little technical experience with this stuff...but I follow directions really well.
Is this as simple as following the installation disk instructions that come with the Netgear router?
NETGEAR N750 Dual Band 4 Port Wi-Fi Gigabit Router (WNDR4300)
I've got all the addresses needed from CenturyLink to complete the connection.
Or...am I in over my head and need to hire someone smarter than I?
Thanks for any help or advice you wizards might have.
Message 1 of 6
Accepted Solutions
goodguys
Re: How to install wireless router to AdTran equipment
up and running!  plug and play.
thanks guys.
Message 5 of 6
All Replies
You can't break anything by trying yourself.
Manual and Quick Start guides are here:
WNDR4300v2 | Product | Support | NETGEAR
Message 2 of 6
goodguys
thanks!  I'll see how it goes today.
I appreciate your response.
Message 3 of 6
Pay attention to the order in which Netgear advises that you turn things on. It can be important.
Message 4 of 6
goodguys
thanks guys.
Message 5 of 6
Congratulations. You are clearly better at this stuff than you claimed.
Otherwise it would be a case of plug and pray.
Message 6 of 6
Top Contributors
Discussion stats
  • 5 replies
  • 4046 views
  • 2 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
