× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
How to manage my R6400 router from PC. I don't want Nitehawk App on my phone.
Jno2
Tutor
How do I manage my R6400 router from PC.     It used to be routerlogin.net, but no longer...
I do not want the Nitehawk App on my (old) phone.
What do I do?
Thank you.
Model: R6400|AC1750 Smart WiFi Router
Message 1 of 5
Accepted Solutions
Guru
Re: How to manage my R6400 router from PC. I don't want Nitehawk App on my phone.
if you're on windows
open a command prompt (click on start and type cmd)
type ipconfig  and hit enter.
the default gateway address should be your routers address. This isn't always the case if you're in a double nat situation.
https://www.howtogeek.com/233952/how-to-find-your-routers-ip-address-on-any-computer-smartphone-or-t...
Message 4 of 5
All Replies
Guru
You can log into it using the ip address of your router.
That's all I use for accessing mine.
Message 2 of 5
Jno2
Tutor
It was suggested I long in with the IP address of the router. How do I find that?
(using a PC)
Message 3 of 5
Guru
Message 4 of 5
Jno2
Tutor
That  got me the IP and I'm in.
Thanks.
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 1280 views
  • 1 kudo
  • 2 in conversation
Announcements
Orbi WiFi 7
