NRod84
Oct 04, 2017Aspirant
Internet blinking amber rapidly
So I just moved and transferred over my service with same modem and router. Internet is working just fine if I plug the Ethernet directly into my laptop, but when I plug it into router the internet light blinks rapidly an orange/amber color and all devices show connected to wireless network but no internet access. I have tried power cycling both modem and router and no changes. I’ve had no issues with either in the past.
- ElaineMNETGEAR Employee Retired
Welcome to the community, NRod84
The router may probably need reconfiguration.
Who is your ISP?
Try to follow the steps from the article below.
I recently lost my internet connection, how do I get my connection back?
- NRod84Aspirant
ElaineM wrote:Welcome to the community, NRod84
Who is your ISP?
Thank you, Elaine. My ISP is Spectrum/Time Warner. My router and this current modem worked just fine at my last place, so I'm unsure what happened in the move/transfer. I tried calling Spectrum and a tech walked me through the basics, but nothing changed.
I will see if the article you linked helps me.
- NRod84Aspirant
Ok, so I read the article. I already tried powercycling and nothing.
I downloaded the latest firmware, but am supposed to connect my router via ethernet to my computer and log into www.routerlogin.net to manually update it. However, I'm using a laptop and only have one ethernet port and I need that to connect directly to modem to have internet.
Am I missing something? Or can I log into my router offline?
> I downloaded the latest firmware, [...]
Ok.
> [...] I'm using a laptop and only have one ethernet port and I need
After you've downloaded the firmware kit, why do you need to maintain
Internet access? Forget the Internet. Connect your computer to your
router, and do the firmware update.
Probably. [www.]routerlogin.net should point to your own router, not
to some outside-world Web site.
