bfieldsAspirantApr 15, 2021My router/modem won't connect to internetLaptop will connect to wireless but will not connect to internet?
5 RepliesReplies sorted by OldestplemansGuru - Experienced UserApr 15, 2021Can wired devices connect to the internet? what have you tried doing to fix it? (reboot, factory reset, etc)bfieldsAspirant to plemansApr 15, 2021Factory reset worked but now the upstream light is orange??plemansGuru - Experienced User to bfieldsApr 15, 2021If you log into it, you can view the cable connections page. Take a screen snip of that and post it back here. It shows things like upstream/downstrea/snr, etc That helps check the connectionShow More
