Bashir639's avatar
Bashir639
Port forwarding on WNDR 4500
Im using a WNDR4500. Im not sure which version, but Netgear genei doesnt say if its any particular one so I assumed it was the first one.
Im trying to host a server from my computer that my friends can play on, and I'm trying to do this through port 25565. The internal ip of the device that the server runs off of and my friends are supposed to connect to is 192.168.1.26.
I went to the advanced setup and followed every tutorial I could find on protforawarding. You can see the port forwarding settings in the image below. Everything seems as it should be but when I go to a Open port checker and enter my external ip: 75.89.xxx.xxx, it says my port isnt opened. I then tried entering my private ip: 192.168.1.26 and that still showed no results. I've followed a couple of forums already on the topic on this site but I still couldnt find anything that would help. Please mind that I am quite new to this stuff and forgive me if I show any ignorance.
  • Ok I figured it out! When you mentioned a NAT Router blocking my port I did some researsh to understand what you meant. To put it in layman terms for people like me, it means that the motem box is blocking your router from connecting to the outside world. I connected to my motems network and when into its settings (Im using Windstream) and I disabled all the firewalls. The I made a new port. I took the internal IP that was belonging to my router: 192.168.254.64 and ported port 25565 using TCP/UDP. Then the port checker was displaying my port was open and my firends were able to join my server. Thank you for the kind help, and I'm sorry if I gave you any hard times!!!
  • I noticed that my image didnt upload well so heres a list of the port settings:
    Service Name: Minecraft Server
    Service Type: TCP/UDP
    External Starting Port: 25565
    External Ending Port: 25565
    Use the same port range for internal port: checked
    Internal Starting Port: 25565
    Internal Ending Port: 25565
    Internal IP address: 192.168.1.26 (This si the IPV4 address of the laptop thats running the server)
    • antinode's avatar
      antinode
      Guru
      > Im using a WNDR4500. [...]
         Connected to what?  Some kind of modem or other?
      > [...] every tutorial I could find on protforawarding. [...]
         The non-psychics in your audience may have little idea what you could
      find (or where you looked).
      > [...] when I go to a Open port checker and enter my external ip:
      > private ip: 192.168.1.26 and that still showed no results. [...]
         Which "a Open port checker"?  To any outside-world system, an
      (unroutable, private) address like 192.168.1.26 would be unreachable.
      "75.89.xxx.xxx" is a public address, but see item 1, below.
         The usual problems with this stuff are:
         1. Wrong external IP address (different from the port-forwarding
      router's WAN/Internet IP address).  (An intermediate NAT router, for
      example, could cause this.  Or an ISP using carrier-grade NAT to
      conserve IPv4 addresses.)
         Does the IP address of the WAN/Internet interface of your router
      match what you're using as your public IP address from the outside
      world?  ADVANCED > ADVANCED Home : Internet Port : Internet IP Address
         2. Bad port-forwarding rule (wrong port(s), wrong target address --
      including a wandering target).
         Yours looks reasonable.
         How did you ensure that your game server system always has the right
      IP address?  Static configuration?  Reserved dynamic address?
         3. Server not listening on the port-forwarding target system.
         Can you access the server from a system on your LAN using the
      server's LAN IP address?  If you can't access the server locally, then
      there may be little chance of doing it from the outside world.
         If that works, then, still from a system on your LAN, try using the
      router's WAN/Internet IP address.  That should verify the
      port-forwarding rule(s) (and the "NAT loopback" feature of the router).
         4. External influences: ISP blocking, other firewalls, ...
      Seldom the problem.
      • Bashir639's avatar
        Bashir639
        The router is connected to a motem that I got from Windstream, im not sure what model it is though.
        I followed multiple tutorials on how to port forward for the game (Minecraft) on youtube, then I went to Reddit, then I went here. I followed around 5 or 6 forums on this website but I couldnt find anything.
        I was using https://www.portchecktool.com/ and https://www.yougetsignal.com/tools/open-ports/ which both say the port is closed.
        Im not sure how to check if im using the wrong external IP address. I dont have an intemediate NAT router, and I'm not sure how to check if my ISP is ussing a NAT to conserver IPV4 addresses and im not sure what that means either.
        When I go to advanced home I find the ip: 192.168.254.64. I thought my public ip adress was the 75.89.xxx.xxx number, so if thats so, then they are not the same. But I beleive I'm mixing something up here.
        Im currently just trying to get the server to connect to others. I planned on making the IP static after I got the port opened, but if its a big deal I can try to make it static.
        Yes I can access the server on LAN with the servers LAN ip address. I can also access it with the ip address found in the advanced home menu you mentioned earlier.
        When I use https://www.portchecktool.com/ it says that the website cant connect with the port dure  to the conncetion timing out rather than prompting it was refused by a potential firewall or ISP block.
