× Introducing the new Orbi 770 Series Mesh System. To learn more click here.
Orbi WiFi 7 RBE973
Reply
R6300v2 Can't Logon - Serial number not recognized
Seelaender1
When I put the serial number on the label off the back of my R6300v2, the one just above the MAC address, into the when Router Password Recovery screen, it states "The information you entered does not match what is saved on the router. Please enter it again."
Does some know how to fix this?
Router model: R6300v2
Serial Number: 4SL60BB0A0830
On a private network, not externally accessible.
Reply to: rseelaender@earthlink.net
Thanks.
Message 1 of 4
Accepted Solutions
Guru
Re: R6300v2 Can't Logon - Serial number not recognized
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
https://kb.netgear.com/24231/How-do-I-back-up-the-router-configuration-settings-on-my-Nighthawk-rout...
Enjoy. 📡
Message 4 of 4
All Replies
Guru
You'll need to factory reset the router and setup from scratch by pressing the reset button for 10 seconds then release. Wait for the router to come to ready, then log in to 192.168.1.1 using a web browser and walk thru the setup wizard. This time write down all important information for safe keeping later on.
Message 2 of 4
Seelaender1
Thank you for the reply. I was able to reset the router.
Message 3 of 4
Guru
Enjoy. 📡
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 1671 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
