LBryan's avatar
LBryan
Follower
Dec 31, 2021
The modem has blinking amber upstream but no other lights are on.
Only the power and the upstream light is on for the modem, the upstream light is blinking amber. I am seeing WiFi being provided to my mobile devices but when using WiFi nothing actually loads. I’ve already contacted my ISP and they haven’t been helpful to me at all. I don’t know if this is a modem issue or an ISP issue.
  • plemans's avatar
    Do you have a screen snip of the modems cable connection page and event logs?
    Also, check your coax line for kinks, damage, old/bad/cheap/loose/corroded connections. Replace them if there are.
    Remove any splitters, amplifiers, or signal attenuators from your line.
    The CM500 is a cable modem, no router involved, so not really a suitable subject for a section given over to General WiFi Routers (Non-Nighthawk and Non-Orbi).
    That doesn't mean that you won't get help here, just that you won't find much related to your modem around here.
    You might do better to try here too  Cable Modems & Routers
