3924router
Jun 10, 2024Follower
Wifi pool timer
How to connect 2.4ghz pool timer
Something to ask the pool timer Mfr about. They should know how to do this.
What router do you have?
What error are you running into?
What pool timer do you have?
Why do you think the Netgear support forums can help setup a pool timer and not the pool timer manufacturer?
Connect to what?
