maxarch
Aug 04, 2016Aspirant
which model of router have a wifi on/off button
i am looking to know witch are routter have a on/off swich for the wifi like this model
NETGEAR Wireless-N 150 DSL
- AnonymousAug 04, 2016
Most routers have a wifi button to turn on and off wifi.
Pick a router you're interested in then locate the manual and check it.
- Anonymous
maxarch wrote:i am looking to know witch are routter have a on/off swich for the wifi like this model
That is not a Netgear model. It is a wifi standard.
So do what searay suggests.
Decide on what you want the router to do, find a model that has those features, then check that it has an off/off switch for the wifi.
- maxarchAspirantI know I can go on the control panel with my computer and turn on and off the Wifi. What I meet it a physical button on the case that you can press to switch on and off the WIFI signal. For the moment I have a D-Link dir-615 router, I can turn on and off by going to the control panel change the setting reset the modem wait 1 min that it reboots. I want an easier methode.like the model NETGEAR Wireless-N 150 DSL have a physical button on the case.
- Anonymous
Read my post again slowy..............
