Orbi WiFi 7 RBE973
Reply
SFP Ports FS728TP switch
JAB05
Will an addoncomputer.com JD118B-A0 (1000Base-SX SFP MMF function in a FS728TP switch?
Message 1 of 4
Accepted Solutions
JAB05
Re: SFP Ports FS728TP switch
Thank you for the input..
Will try the AGm731f-A0
Message 3 of 4
All Replies
JohnRo
NETGEAR Employee Retired
Hello JAB05,
Welcome to the community!
I understand you have some questions regarding compatibility of SFP modules on our switches, let me help you with that. Since the JD118B-A0 is also a 1000Base-SX SFP module, there is a chance that it might work but there is no assurance in that. I have seen some users reported that have used other modules on our switches and they worked fine. See compatible modules below:
AFM735 100Base-FX SFP GBIC (Multimode)
AGM731F 1000Base-SX SFP GBIC (Multimode)
AGM732F 1000Base-LX SFP GBIC (Single mode)
Hope it helps!
Thanks,
Message 2 of 4
JAB05
Message 3 of 4
JohnRo
Hi JAB05,
You're welcome! Unit should be plug and play so you shouldn't experience any issues installing.
Thanks,
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 4109 views
  • 0 kudos
  • 2 in conversation
Announcements
