Boyan81
Dec 16, 2020Follower
Does GS108PE support SNMP for the purposes of using a tool like Cacti to monitor ports?
Hi Everyone,
I can manage the switch via it's web GUI but I can't find any way that I can monitor the switch in terms of ports utilization, bandwidth, etc thins which I normally would expect to be able to collect via SNMP
Thank you
Boyan
1 Reply
Boyan81 wrote:Does GS108PE support SNMP ...
Consulting the product data sheet and the documentation can give you the answer.
Try your luck here FMI https://netgear.com/support
It's simple "No".
Boyan81 wrote:... a tool like Cacti to monitor ports?
Cacti does allow much more than just SNMP, stuff like cgi, shell, whatever. MIght be difficult to gain an unattended access on these devices.
Boyan81 wrote:I can manage the switch via it's web GUI but I can't find any way that I can monitor the switch in terms of ports utilization, bandwidth, etc thins which I normally would expect to be able to collect via SNMP
These simple switches are essentially unmanaged cores which allow some basic config, and offer a very small amount of statstics only.
- May 25, 2022Retired_Member
