× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
AC7000 genie wont start
CorbinGallion
Follower
I downloaded the A7000_V1.0.0.15_Windows file to install the genie so the genie will give me the program yeah well I installed it and waited for the genie to open so i could start the setup and it wasnt opening I uninstalled it then reinstalled it still nothing idk if im dumb or something i really need help
Message 1 of 3
Guru
Re: AC7000 genie wont start
I usually use the stand alone driver and just let windows manage the wireless connection setup. Have you tried that?
Message 2 of 3
I'm guessing here, but I think that @plemans is referring to the "SA" program mentioned in the release notes:
A7000 Software Version 1.0.0.15 (Windows) | Answer | NETGEAR Support
You will find that the zip file contains two exe files.
Try A7000_Windows_Standalone_V1.0.0.15.exe
Or see if the native drivers in Windows will work.
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 1018 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
